CS3 HDV – Audio and Video out of sync.
I imported footage (HD-1080i) from my Canon HV20 into my PC (CS3 Capture) via the standard issue on board firewire port. When playing back the footage in my timeline, the audio and video start drifting after so many minutes. I have no third party capture/playback baord, etc. I think I know the answer but thought I would throw this question out there just in case I was wrong.
Do I need a third party card, such as a Matrox RT2 card, in order to keep both audio and video in sync among other things. If that’s the case can ayone recommend a board that’s in the $1200 price range. ‘Sounds like the Matrox board, RT2, might be too finicky?
Or is it simply anothet problem?
Here’s my system’ specs:
Dell XPS630 w/quad core processors (6600), 4 gigs of memory, Inernal Seagate SATA drive with 79 mb tested performance. Software: CS3 v3.1.1. Audio and video are recorded onto the same drive – drive is seperate from the system drive. Audio is supplied via the inernal audio card.Thanks,
Dave
