Activity › Forums › Adobe Premiere Pro › CS3 Export Window???
  • CS3 Export Window???
    Posted by Larry Zapotocky on February 7, 2011 at 3:22 pm
    I’m using CS3. When I go to File, Export, Adobe Media Encoder, I get the encoder window, as usual, to select the export settings.
    After I select my settings, I click on OK and the screen looks like it is going to go to the window where it saves the file to and nothing happens.
    I’ve tried this with multiple export settings and it does the same thing. I’ve been using Premiere for many years and never encountered this?
    Thanks for your help.
    Larry
    Larry Zapotocky replied 15 years, 7 months ago 2 Members · 2 Replies
  • Brian Louis
    February 7, 2011 at 6:47 pm
    Does the path it was going to save to still exist? if you are using external drives this can be a problem, also have you noticed anything different about the computer lately? have you tried a different restore point to eliminate possible computer problems?
  • Larry Zapotocky
    February 8, 2011 at 4:43 pm
    Hi Brian,
    I started a new project and imported the original one and still the same thing. I then opened a completely different project and imported the video in and it worked.
    I then went back the original project and created a new sequence and copied the video and it worked.
    For some reason, it was the sequence that wasn’t working. I’ve never had that happen before and I was confused.
    Did I confuse you even more?
    Larry
