CS3 and Windows XP 64bit
I recently upgraded to 6GB of RAM so i installed XP Pro x64 so I could use it all with the CS3 suite.
For some reason everything sometimes gets really slow and weird. Updates dont show and the windows kinda freeze up until you click them. I have to scrub around a lot to get stuff to show up.
But it’s not just AE, its PS and Illustrator too.Is there some kind of bug or anything With XP Pro x64?
I only have SP1, so I might update to SP2 and just see.Are there any specific settings I should change in AE and PS to make it run better?
I have a good amount of HDD space I can use as a scratch disk, but I dont know if that helps.
