CS2 dimension problems
Hi, when I work in CS2 and i set an image to be for example 10 cm X 10 cm and double check on the grid to make sure the dimensions are right, the exported file does not match the dimensions I had the set the image to, It’s really frustrating,
Basically, the dimensions in CS2 do not correspond to the dimensions of the exported file.
If anyone has a clue about this problem, please help,
thnks
