Activity › Forums › Adobe Premiere Pro › cs 5.5 no recognize my second monitor
  • cs 5.5 no recognize my second monitor
    Posted by Jose Arce on July 14, 2011 at 4:54 pm
    Hi, today my Premiere pro cs 5.5 don’t send image to my second monitor, is the second time that happen to me, and the option in the sequence settings desapear.
    I use a single graphic card, the ATI Radeon HD 4870 on a Mac Pro Quad-Core Intel Xeon 2008.
    If anybody can help me.
    Matthew Lincoln replied 14 years, 4 months ago 3 Members · 3 Replies
  • Vince Becquiot
    July 14, 2011 at 9:42 pm
    Hi Jose,
    You monitor has to be set to extended (not mirror), and be turned on before you start Premiere. Other than that, latest drivers is all I can think of.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Jose Arce
    July 16, 2011 at 10:59 pm
  • Matthew Lincoln
    May 8, 2012 at 8:09 pm
    Hey There:
    I just experienced this problem, and found no answer online. Then I discovered that intermittently, if any part of your premiere window occupies the second monitor, even a hair, you won’t be able to see the second monitor in your playback settings. It will work if this setting is already activated, but won’t work if you are trying to turn it back on. And again, intermittently a problem, though this is always how I solve it now. Bizzarre, but hope this helps!
    -Matt
