Activity Forums Adobe Premiere Pro CS 5.5 is moving my keyframes on me
  • CS 5.5 is moving my keyframes on me
    Posted by John Young on July 18, 2011 at 8:45 pm
    I have noticed some instability with my new upgrade to CS 5.5 when it comes to keyframes. I like to use keyframes in Premiere when doing simple moves and animations, but lately I have been getting frustrated with Premiere for adding extra keyframes on it’s own or changing the value on existing keyframes.
    I notice this most when I have a nested sequence in my timeline and I apply a simple effect to that nested sequence. So I will keyframe a simple move, (say changing size from 66.7% to 100%), then do some editing elsewhere in the timeline and when I come back and preview the sequence, the keyframes I set have been changed. It always seems to happen on the first frame. Often if there are keyframes at then end of a clip, but none at the beginning, I am finding Premiere creating a keyframe at the first frame in the clip that changes the effect significantly. It happens most with nested sequences but I have noticed it only regular clips as well.
    I decided to post this because I just did an export and noticed an effect that was changed. So I had to go back in, change it and re-export. Then after that output I noticed a completely different effect was changed, that wasn’t changed on the first export.
    Is anyone else finding this, or am I doing something wrong?
    Thanks in advance.
    John
    http://www.johnathanyoung.com
    Kevin Monahan replied 14 years, 11 months ago 4 Members · 3 Replies
  • Robert Brown
    July 20, 2011 at 3:04 am
    I’ve seen this too. I haven’t sorted out when it happens but have had a simple 2 KF animation and come back to find a new KF usually put on the first frame of the clip where there was not one before.
  • Carolyn Moore
    October 13, 2011 at 4:57 pm
    I’m having the same problem with the first keyframe changing value. It appears to be happening right after I save the project. Any thoughts?
    Carolyn
    Carolyn Moore
  • Kevin Monahan
    October 14, 2011 at 7:04 pm
    Could you folks file this as a bug? I had the same issue: https://www.adobe.com/go/wish
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
