Activity Forums Adobe Premiere Pro CS 5.5 Audition
  • CS 5.5 Audition
    Posted by Paul Rozon on July 1, 2011 at 5:02 pm
    Just took delivery of a brand new PC with CS 5.5 installed using Matrox MXO2 LE
    I went to record a voice over in Audition but Audition did not recognize Matrox at the inputs. Went in to Audition preferences/audio hardware to configure inputs but nothing there from Matrox. It does recognize Matrox for audition outputs.
    Premiere recognizes matrox audio in and out.
    Anybody with similar experiences?
    Tim Kolb replied 15 years, 2 months ago 2 Members · 3 Replies
  • Tim Kolb
    July 2, 2011 at 12:37 am
    I’m not as familiar with Matrox’s most recent offerings…there may be a hangup there, but it’s anything I’ve heard about.
    In the short term, you do know you can arm an audio track to record on the sequence in PPro, right? If the external device seems to play nice with PPro, that may be a short-term work around.
    …actually, since you can do it while the sequence is running, you could pace it visually if you’re narrating to picture…
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Paul Rozon
    July 2, 2011 at 3:02 am
    Thanks for your response Tim.
    We had established that as a workaround. It is a bit slow but it get the job done.
    Still hoping we can resolve this issue.
  • Tim Kolb
    July 2, 2011 at 3:28 am
    I would make sure I bounced this around with Matrox as well. It may be a matter of them having some driver updates to shift between Soundbooth in CS5 and Audition in 5.5…
    TimK,
    Kolb Productions,
