Cross Fade in MultiCam
Posted by Steve Edwards on November 28, 2007 at 11:03 pmIs there a way to do a cross fade/disolve when you are using the multicam feature If so, how is it done.
Edward Troxel replied 18 years, 10 months ago 4 Members · 9 Replies -
Rick Mac
November 29, 2007 at 2:01 amHold down the control key while selecting your camera
will create a crossfade instead of a cut.Regards, Rick.
Rick Mac
Director of Audio Production
TCT Network – Directv 377 -
Steve Edwards
November 29, 2007 at 5:41 amWill it change the length on the audio timeline. Also when dragging a clip, say to the right, how do you get the audio and video tracks to move together. I had some problems with that tonight. Don’t remember having that problem before.
Edward Troxel
November 29, 2007 at 2:40 pmThe new audio length should match the new video length. Unless the events have been ungrouped, they should move together. There are multiple ways to move multiple events. You can use the event selection tool to select a group of events and then move them all at once.
Personally, I use a script to select the group of events to be moved. That way I can easily select “all events after the cursor on all tracks”, for example.
Steve Edwards
November 29, 2007 at 5:01 pmA couple of other questions, sorry! If I am using multicam and want to cut & crossfade both sets of tracks (2 cams), how is this done? Do I go to “select all”, and then cut and crossfade? Also if I use Escalibur, is there a way to put all the clips of camera #1 as 1 camera entry? I have about 6 clips for camera #1, and 1 clip for camera #2. When I followed the directtions it told me to add the clips for each camera. This ended up in me having 7 sets of tracks instead of just two.
Edward Troxel
November 29, 2007 at 5:26 pmTake a look at Vol 1 #9 of my newsletters. It gives several manual methods of doing multi-cam.
Using either the new multi-cam in Vegas 8 or Excalibur, you can have ALL of camera 1 on a single track. Just leave gaps where the camera was turned off. You don’t need a new track for each new segment.
Sebastien Gravel
November 29, 2007 at 11:39 pmI was wondering, I have used the multicam tool, but I only did straight cut. Is it possible to transform all of them into crossfade without disturbing the audio?
Edward Troxel
November 30, 2007 at 2:32 pm -
Edward Troxel
November 30, 2007 at 2:49 pmBut I don’t have one that does that particular task – at least not “en masse”. It CAN be done, and I do it in my multi-cam script but I do it during processing the camera switches – not after the fact. My normal “overlap” script will create the dissolves but doesn’t lengthen the events.
