Activity Forums Apple Final Cut Pro Legacy Cross dissolve issue
  • Cross dissolve issue
    Posted by Jesse Austin on April 30, 2010 at 4:51 pm
    can some one out there tell me why this is happening????
    I have two HD 1920×1080 clips both have been color corrected. I have placed a 1.15 cross dissolve between them, render it out looks perfect. Once I export the time line, during the cross dissolve the video is un color corrected once the next frame of incoming video happens you can notice the difference between the two. I have tried all different types of export settings an not go
    Please help
    Jess
    Kevin Monahan replied 16 years, 4 months ago 3 Members · 12 Replies
  • 12 Replies
  • Jeremy Garchow
    April 30, 2010 at 5:10 pm
    What is the source of your video?
  • Jesse Austin
    April 30, 2010 at 5:15 pm
    Thanks for getting back..
    It is from the sony ex1, edcam ex 1080p30
    Jess
  • Jeremy Garchow
    April 30, 2010 at 5:16 pm
    What’s the codec or your timeline?
  • Jesse Austin
    April 30, 2010 at 5:27 pm
    The time line setting are as follows
    1920×1080 HDtv1080i (16×9)
    Square
    23.98
    Compressor: xd cam EX 1080p30
    Jess
  • Jeremy Garchow
    April 30, 2010 at 5:31 pm
    [jesse austino] “23.98
    Compressor: xd cam EX 1080p30 “
    Why a 24p timeline when you shot 30p? I’d start there.
  • Jesse Austin
    April 30, 2010 at 6:11 pm
    I hade a feeling you were going to say that. Not to sure myself, I will change it up an go from there
    Jess
  • Jesse Austin
    April 30, 2010 at 7:07 pm
    Hey,
    You know I have changed the time line setting to 30, still no go.
    What is wired is this- if I export a QT movie self contained and leave the Current Setting along it looks just a the time line does perfect. As so as I change it up that is were the problem starts and forget about trying to use QT conversion.
    Jess
  • Jeremy Garchow
    April 30, 2010 at 7:08 pm
    [jesse austino] “What is wired is this- if I export a QT movie self contained and leave the Current Setting along it looks just a the time line does perfect. As so as I change it up that is were the problem starts”
    What are you trying to change it to?
  • Jesse Austin
    April 30, 2010 at 7:15 pm
    I wanted to get the best possible settings, Prores422HQ. The clip will be projected at 720×1208
    Jess
  • Jeremy Garchow
    April 30, 2010 at 7:17 pm
    [jesse austino] “The clip will be projected at 720×1208 “
    I assume you mean 1280×720.
    Fully render your timeline, then export a reference movie (current settings, leave recompress all frames and make self contained UNchecked) then bring that movie in to COmpressor and use that to make a 1280×720 ProRes 23.976 fps movie. ProRes will be just fine, no need for HQ in this instance.
    Jeremy
