Activity Forums Apple Final Cut Pro Legacy Cropping the frame
  • Cropping the frame
    Posted by Areful Eeslam on December 28, 2010 at 7:52 pm
    I shot DVCPRO HD 720PN footage with Panasonic HVX200. The camera itself shoots 1.78:1 ratio as in 16:9 format. I shot all the footage with 2.35:1 framing in mind. Now i cant change the ratio or rather crop the extra bottom & head using FCP. Please help…..
    Thanks in advance
    Regards
    David Roth weiss replied 15 years, 9 months ago 2 Members · 3 Replies
  • David Roth weiss
    December 28, 2010 at 8:23 pm
    [Areful Eeslam] “Now i cant change the ratio or rather crop the extra bottom & head using FCP. “
    Correct! FCP uses standard video sizes. And, just like Hollywood movies on DVD, widescreen formats are formatted to fit the standard video screen size, rather than the other way around. If you wish to edit in FCP without the letterbox top and bottom in FCP you will have to scale you video up to fill the frame, thus eliminating portions of the horizontal frame on the right and left. Or, you could try cutting in a seq. set for 2K, at 2:1 and scale accordingly.
    You would have to use Compressor or another encoding app to crop to the widescreen format after editing.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Areful Eeslam
    December 29, 2010 at 10:02 am
    Trying the 2K setting. cant crop the frame on horizontal left or right. i intend to make HD output for preview not dvd.
    thanks
  • David Roth weiss
    December 29, 2010 at 4:26 pm
    Cropping isn’t the answer — you have scale the video up slightly to make it fit into the 16×9 or 2:1 video frame. However, like a Hollywood DVD, you’re going to end up with letterbox black on the top and bottom, as DVD specs are also very specific about frame size. Widescreen DVDs are all 16×9, period, end of story, none are 2.35:1. or 2:1.
    David Roth Weiss
    Los Angeles
