Activity Forums Adobe Premiere Pro Cropping the frame
  • Cropping the frame
    Posted by Areful Eeslam on December 28, 2010 at 7:54 pm
    I shot DVCPRO HD 720PN footage with HVX200. The camera itself shoots 1.78:1 ratio as in 16:9 format. I shot all the footage with 2.35:1 framing in mind. Now i cant change the ratio or rather crop the extra bottom & head using Premiere. Please help…..
    Thanks in Advance
    Regards
    Areful Eeslam replied 15 years, 9 months ago 2 Members · 2 Replies
  • Andrew Devis
    December 29, 2010 at 2:15 pm
    Hi Areful
    I’m not sure if this is the right answer for you, but you can create custom sequence sizes by creating a new sequence and then clicking on the General Tab and then from the very first drop-down (Editing Mode) choosing ‘Desktop’. This will then allow you to change settings that are greyed out when a standard preset is selected including frame size and video previews.
    Hope this helps
    Andrew
    … because it’s all about stories …
  • Areful Eeslam
    December 30, 2010 at 5:43 pm
    thanks, will try for sure
