Activity Forums Apple Final Cut Pro Legacy Cropping out a corner.
  • Cropping out a corner.
    Posted by Keith Mccreary on August 6, 2009 at 9:29 am
    I shot some video with a green screen, and it turned out quite good, but I used a circular green screen and in a few shots, the top right corner of the screen was not green. There is movement to the left and below the corner, but nothing intersects the troubled area. I just want to crop it out, but I can’t figure the best way to do that. I tried enlarging the whole video which solves the problem but it cuts off some of the actor’s head.
    What I really need to do is simply crop a corner, not a side. I can’t find a simple way to do this. Any advice?
    Keith Mccreary replied 17 years, 1 month ago 2 Members · 2 Replies
  • Olof Ekbergh
    August 6, 2009 at 11:55 am
    Use a garbage matte, in AE this is easy. Most Keying programs will have this function.
    Olof Ekbergh
  • Keith Mccreary
    August 7, 2009 at 12:14 am
    I knew there had to be a simple solution that I just wasn’t thinking of. Thanks!
