Activity › Forums › Apple Final Cut Pro Legacy › cropping 16×9 to 4×3 (HD or SD)
Posted by David Carey on April 11, 2007 at 8:46 pmWhat is the best was to crop 16×9 clips for a 4×3 final presentaion in FCP?
thanks
David Carey replied 19 years, 5 months ago 2 Members · 3 Replies -
David Carey
April 12, 2007 at 5:03 amI want to crop the 16×9 so that it fills the 4×3 frame without distortion. In other words: crop off the two sides.
Devin Crane
April 12, 2007 at 1:54 pmYou will have to import it into a 4×3 timeline, distort the 16×9 footage to -33.33 so that it isn’t distorted on the timeline, scale it up to 133% I believe. Then you will have to do a full render so that the dark green render bar is dark blue. I’ve noticed that this will get the best results.
