Activity Forums Adobe After Effects Cropped Nested Comps
  • Cropped Nested Comps
    Posted by Jared Mohney on November 12, 2010 at 4:09 pm
    Hi there! Long time lurker, first time poster.
    I have pre-composed a series of animated layers which come flying inward from the outside of the screen. I then scaled this composition and turned it in 3d space, only to find that the outside areas of the original layers are now cropped off.
    I basically nested the animated files for easier 3d manipulation but now that I have, I cannot see them flying inward, only once they’ve reached the viewing area on the original comp.
    Is there a way to fix this?
    Example: Let’s say I have 4 letters flying to the center of the screen to write the word “love”, I then precompose these animations and scale it down, now I see cropping of the letters and clearly see where the nested comp size ends. How do I go about making it so I can see what was going on outside the nested comps viewing area when scaled down in the main comp?
    Hopefully, this makes sense…
    Jared Mohney replied 15 years, 9 months ago 3 Members · 3 Replies
  • Erik Waluska
    November 12, 2010 at 4:20 pm
    “Long time lurker, first time poster.”
    Haha. I like that.
    Anyway, it sounds like you just need to either turn on the “collapse transformations” switch for the nested comp, or if that interferes with the animation you are trying to do with the nested comp, then just make dimensions of the nested composition as large as required so you don’t see the clipping you are describing.
    HTH
  • Roland R. kahlenberg
    November 12, 2010 at 4:21 pm
    Try switching on Collapse Transformation for the nested comp.
    HTH
    RoRK
    AE Training in South East Asia. AE templates for sale and rental. Click here for more
  • Jared Mohney
    November 12, 2010 at 4:35 pm
    Thanks guys! Works like a champ!
