Activity Forums VEGAS Pro Crop turned out different after rendering?
  • Crop turned out different after rendering?
    Posted by Miles French on May 9, 2010 at 4:43 pm
    First of all I just want to give the thanks we all know the forum users deserve for answering all our questions. It wouldn’t be possible without you guys!
    So this usually only happens when I composite something into the video like a gunshot. When viewed on the sample screen its perfectly cropped but after rendering it the gunshot appears in a different place. This is incredibly annoying and makes compositing look horrible. I am sure it has something to do with the size of the project and how I render it. I rendered it into a 1280 by 720 while the sample was smaller. How can I fix this?
    Miles French replied 16 years, 4 months ago 2 Members · 2 Replies
  • John Rofrano
    May 10, 2010 at 12:40 am
    The trick is to work at the same size you will deliver. So if you are delivering 1280×720 then your project should be 1280×720 and your preview should be set to at least Good Full when you line things up.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Miles French
    May 10, 2010 at 2:46 am
    ok thanks! You guys are just so helpful!
