Activity Forums Adobe Premiere Pro Crop hi-res JPG timelapse to a panning, zooming HD frame
  • Crop hi-res JPG timelapse to a panning, zooming HD frame
    Posted by Lopici Gaspar on March 11, 2024 at 9:55 pm
    The sequence has a timelapse made up of sequential 7008 x 4672 jpg images, so that’s the default video dimension.
    How can I crop out an HD (1920 x 1080) dimension that slowly moves (pans) across and/or zooms in/out (i.e., not just cutting down to a static HD frame)?
    Brie Clayton
    replied 2 years, 5 months ago
    4 Members · 4 Replies
  • Larry Chapman
    March 11, 2024 at 10:19 pm
    To control each image’s motion separately – Drop the images onto a 1920×1080 sequence and keyframe the motion of each.
    Or…drop your full resolution image sequence into a 1920×1080 sequence and keyframe that. I believe this option is what you’re looking for.
    March 12, 2024 at 10:28 am
    Hey Lopici,
    Assuming that the time-lapse has been processed to deal with exposure changes and other fun stuff that happens when one is standing in a spot for hours and hours, you could just import the sequence as an “image sequence”, so it appears as a video asset.
    With regard to the size of it, as Larry suggested, when you pop it in the timeline, you can use the Effects Controls to re-size, add keyframes to make Zoom and Pan across the video.
    Using a nested sequence within your HD Sequence is another consideration.
    But it all comes down to the power of your hardware and the length of your time-lapse, in which case it might be more economically to turn the JPeg images into video?
    Many potential solutions, but keep in mind that you will always end up on 1920×1080. So you might “only” need something that is 4,000 in width, rather than 7,008?
    Only you will know, when you see it on your screen.
    Have fun.
  • Lopici Gaspar
    March 12, 2024 at 3:49 pm
    Thank you, worked! 2nd option I am using.
  • Brie Clayton
    March 12, 2024 at 5:42 pm
    Thank you, Larry, for solving this issue!
