Activity Forums Blackmagic Design crop 720 x 486 to 720 x 480 in premiere pro?
  • crop 720 x 486 to 720 x 480 in premiere pro?
    Posted by Lawrence Simpson on June 6, 2005 at 5:11 pm
    Sorry if this seems like a very basic question, but, I couldn’t get an easy answer anywhere. Here goes:
    I am using Premiere Pro with the BMD Decklink HD pro(single link) capturing using the BMD 10 bit NTSC SDI(720×486) job settings. Everything seems to be fine until I try to send the timeline of the captured footage to the Adobe media encoder(ie: 720×480 ntsc). When trying to send the timeline straight to a mpeg DVD output without cropping it looks awful. When I try to add a pre-encode task to crop the 486 to 480 I get an error that the output does not match screen size for the encoder.
    What is recommended for the best way to go from full D1 720 x 486 capture to mpeg for DVD 720 x 480. I have always edited from DV captures via firewire at 480 in the past.
    Thanks for your time!
    David Battistella replied 21 years, 3 months ago 2 Members · 1 Reply
  • David Battistella
    June 7, 2005 at 4:17 am
    Drop your edited sequence into a 720×480 timeline and render that. This way you will loose the six lines you need to loose before the encode and then if it plays back fine as a 720×480 sequence then it sound look fine as an mpeg.
    I am not sure that premiere pro has this capability but I am sure you can adjust you tmeline fram size.
    David
