Activity › Forums › Adobe After Effects › Credit Crawl from Excel Doc
  • Credit Crawl from Excel Doc
    Posted by Benjamin Bernard on October 13, 2009 at 3:07 am
    Hey guys so I have an Excel Doc with the end credits properly spaced out and i brought the doc into AE and then the alignment was all center justified and messed up. I tried right and left but no luck, i think i might be missing a step or there has to be a better way to do it. When i try to just align the text by hand it is unbelievable slow because the text layer is so long, if anyone has any tips or tricks that would be awesome thank you.
    Benjamin Bernard replied 16 years, 11 months ago 2 Members · 2 Replies
  • Kevin Camp
    October 13, 2009 at 2:17 pm
    you might try getting the excel file to pdf.
    if you can’t do a straight export/save as in excel, you may be able to use the print to file method from excel, where you just choose to print the doc, then from the print settings choose to save it as a file, usually pdf.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Benjamin Bernard
    October 13, 2009 at 6:21 pm
    thanks man i bet that will work
