Activity Forums VEGAS Pro Creating XML file in SVP12 from SVP11 veg
  • Creating XML file in SVP12 from SVP11 veg
    Posted by Michael Acres on May 26, 2013 at 8:30 am
    I need to create a XML or AAF file for a colorist who is going to work on a project for me in Davinci Resolve.
    Problem is I am using SVP11 and it is stable and does all I need, but I cant export the file I need.
    My Question is if I send someone the svp11 veg file and they open it in svp12, they wont have the source files, would they able to ‘save as’ a usable XML or AAF file
    Or is there a way to do it from svp11 cuz my searches turned up a lot of dead ends
    John Rofrano replied 13 years, 3 months ago 2 Members · 3 Replies
  • John Rofrano
    May 26, 2013 at 1:44 pm
    [Michael Acres] “Problem is I am using SVP11 and it is stable and does all I need, but I cant export the file I need.”
    The Save as AAF feature you want is in the 32-bit version of Vegas Pro 11.0. I’m guessing you’re using the 64-bit version. Try opening your project in the 32-bit version to save as AAF.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Michael Acres
    May 26, 2013 at 4:28 pm
    yes im on the 64 bit version. I guess I have to pull out the old computer and install svp11 on it :/
    Thanks for the solution!
  • John Rofrano
    May 26, 2013 at 11:21 pm
    You can have both the 64-bit and 32-bit version installed at the same time so no need for another computer. Just install the 32-bit version.
    ~jr
