Activity Forums Maxon Cinema 4D Creating Text with Rounded Edges
  • Creating Text with Rounded Edges
    Posted by Kevin Camin on November 12, 2012 at 5:14 pm
    What would be the best way to achieve text with all it’s edges being slightly rounded? I’m trying to make text that looks like it’s made out of compacted sand (like a sand castle). I’d like to figure out how to achieve the rounded edges, then I’ll be going in with bump and displacement maps to get it uneven looking.
    I’ve been trying to start with a MoText object. Making it into a polygon. Then cutting with the knife around the edges, but I’ve had problems with letters with rounded edges, getting geometry added on those faces.
    So I don’t know if I’m going in the right direction or not. Any help would be appreciated.
    Best regards,
    Kevin Camin
    Kevin Camin replied 13 years, 9 months ago 2 Members · 3 Replies
  • Jeremy Allen
    November 12, 2012 at 7:57 pm
    Look into the Chamfer tool.. It is made to round corners.
    8core MacPro, 3.0 GHZ, 18GB RAM, OSX 10.5.8
    C4D 12
    AE CS5 (10.0.2.4)
    FCP 7.0.3
    QT 7.6.4
  • Jeremy Allen
    November 12, 2012 at 8:05 pm
    Forgot this tool is not in an obvious place..
    Go into point mode, select all your corner points, then go
    Structure > Edit Spline > Chamfer
    Then click and drag to change the amount of rounding.
    C4D 12
    AE CS5 (10.0.2.4)
    FCP 7.0.3
    QT 7.6.4
  • Kevin Camin
    November 13, 2012 at 3:37 am
    Thanks so much!
    Best regards,
    Kevin Camin
