Activity Forums Adobe After Effects Creating Special Shapes In After Effects
  • Dan Ebberts
    April 1, 2012 at 11:56 pm
    You could use corner pin, pickwhip one corner to an adjacent corner, and use expressions like this on the others:
    fromComp(thisComp.layer(“Null 1”).transform.position)
    Dan
  • Kurt Ingamells
    April 2, 2012 at 9:41 pm
    Thankyou Dan, your advice worked like a treat 🙂
    I had to create a shape layer which filled the composition, added the corner pin effect and pick-whipped the lower left corner to the upper left one to turn it into a triangle then from there on I can pick-whip the other corners to my position trackers :p
    Thankyou very much for the advice
