Activity › Forums › Adobe After Effects › creating shape layer paths from an illustrator file
  • creating shape layer paths from an illustrator file
    Posted by Glen Jennings on June 20, 2017 at 10:46 pm
    I’ve got a vector image I’d like to turn into a shape layer in After effects.
    When I copy and paste the paths from Illustrator to the shape layer path, it only makes masks.
    Am I missing something? What’s the correct way to copy/paste your illustrator paths into Shape layers AS paths not Masks.
    If you can’t tell a tale tall then it’s not a tale at all.
    Mark Whitney replied 9 years, 3 months ago 2 Members · 1 Reply
  • Mark Whitney
    June 21, 2017 at 12:29 am
    It’s pretty straight forward although you’ll want to search YouTube for add’l info for prep work that’ll save you a lot of time later with complex .AI files.
    Import the .AI file into AE first. Add the file to your comp. Select the layer and RIGHT CLICK. About 1/4 of the way up from the bottom of the menu that pops up, you’ll see Create Shapes from Vector layer.
    That’s it.
