Activity › Forums › Adobe Photoshop › Creating Sequential Numbers
  • Creating Sequential Numbers
    Posted by Evan Schafer on June 11, 2008 at 5:25 pm
    Is there a way to generate a LOT of sequential numbers, other than brute force, using CS2? I need to create numbers from 1-350 to place on land plots. Placing them will of course take time but, is there a way to simply generate them all automatically?
    Mike Gondek replied 18 years, 3 months ago 2 Members · 1 Reply
  • Mike Gondek
    June 12, 2008 at 12:52 pm
    I create them in Excel, then copy and paste them.
    (EG: in eExcel)
    put a 1 in the top cell
    put a 2 in the cellunderneath
    Then select both cells and drag the blue dot on the bottom right of you selections downwards until you reach 350.
    A far as being abel to move each number individually, my best recomendation would be to then convert this to a vector shape in Photoshop, and then use the solid path selection tool (but be careful not to miss when selcting).
