Activity › Forums › Apple Final Cut Pro › Creating Proxies outside of FCPX
Posted by Loren Risker on October 2, 2012 at 9:47 pmHas anyone had any luck creating proxies somewhere else, such as compressor, so I can use FCP7 while I’m transcoding?
OutOfFocus.TV – Original series, music videos, and entertainment for your couch.Tony Brittan replied 13 years, 11 months ago 3 Members · 5 Replies -
Tony Brittan
October 3, 2012 at 2:04 amMagic Bullet Grinder from Red Giant works great for DSLR footage and what-not of you’re importing directly from an SD card or a complete image of one. Under $50. For free? MPEG Streamclip.
Loren Risker
October 3, 2012 at 6:22 pmMPEG Streamclip is good, but I’d probably use compressor for this. I was just wondering if I could create my own proxy without having relinking issues. I plan to run a test and see what happens.
OutOfFocus.TV – Original series, music videos, and entertainment for your couch. -
Loren Risker
October 3, 2012 at 6:33 pmOk, it does work fine. All you have to do is use the default proxy setting in compressor, then create the path /Transcoded Media/Proxy and drop your proxies in there. Make sure the proxies have the same clip name as the original clip. I have a feeling FCPX will be a lot faster if I do all my transcoding in compressor now.
Mathieu Ghekiere
October 6, 2012 at 4:26 pmTony,
I can be wrong, maybe I overlooked a setting, but in my experience, Mpeg Streamclip, although it converted faster then Compressor, it didn’t retain the original timecode of the original clips.
Which is deadly, if you are relinking, I would think… -
Tony Brittan
October 6, 2012 at 4:28 pmYou may be right on the TC using Streamclip. Grinder from Red Giant is fantastic and will do proxies and full at the same batch for you. It retains everything and works wonderfully. I picked it up for $49 and it was well worth it.
