Activity Forums Apple Motion creating presets from filter keyframe settings
  • creating presets from filter keyframe settings
    Posted by Trace Burroughs on June 21, 2007 at 3:26 pm
    How do I create a preset from filter keyframe settings.
    In other words, I use a filter, I set some keyframes, now I want to make a preset that I can use later.
    Trace Burroughs
    Tracy Burroughs
    Little Men Entertainment
    little-men.com/index2.html
    Doyle Rockwell replied 19 years, 2 months ago 2 Members · 1 Reply
  • Doyle Rockwell
    June 22, 2007 at 6:11 pm
    Heya,
    Everything and anything in Motion can be made into a preset, from the single parameter to an entire project. For example, if you’ve keyframed the Midtone Blue value in a Color Balance filter, you can make a preset of just the Midtone Blue parameter, or you could make a preset of the entire filter. Just drag the parameter (or entire filter, depending on what you want) to the Library, and Motion will make a preset.
