Activity › Forums › Adobe After Effects › creating pedal flowers falling or blowing across in AE 6.5 pro
  • creating pedal flowers falling or blowing across in AE 6.5 pro
    Posted by Mcvideo on December 9, 2005 at 5:24 pm
    I know there is a way to create rose pedals in AE using particle effect. My thoughts are to create the pedal in PS then import into AE. Does anyone know of a site that offers free brushes like a rose pedal that i could use? And is there a tutorial on how to create the rose pedal falling in AE?
    I’d like to try the falling effects and blowing across floor with drop shadow to give a more realistic look..
    Any ideas?
    Thanks in advance.
    Aroonzfx replied 20 years, 9 months ago 5 Members · 5 Replies
  • Steve Roberts
    December 9, 2005 at 5:40 pm
    Try searching the COW under “petals” or “leaves”.
    For realism, though, you can’t beat a 3D app, because then the petal would rotate in 3 dimensions naturally.
    Steve
  • Ron Lindeboom
    December 10, 2005 at 6:27 pm
    Steve Roberts has given you some good suggestions and I will add one — less for your situation and more for the record for those searching the forum later — of a technique my son created which was quite cool visually and had a very stylized look to it.
    He created a layer with a full-sized red solid on it and then duplicated the layer for the number of petals he wanted.
    He then used the masking tools (with some of the mask points being bezier and others being sharp points), to simulate an organic “petal” look.
    He then used the “Emboss Alpha” filter and added a lot of light to the edges to make it looked more rounded.
    He then animated the layers to simulate falling petals in his animation.
    In the end, it was quite pretty and looked a lot like a Japanese image style.
    Best regards,
    Ron Lindeboom
    creativecow.net
  • Justin Productions
    December 10, 2005 at 9:05 pm
    https://www.ayatoweb.com/ae_tips_e/ae19_e.html
    This might be very useful 🙂
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.0 Professional
    December 10, 2005 at 9:08 pm
    Oh, by the way, I have that PS file of the petal roses that took me about 30-40 minutes to do (with a transparency bg) that you need. Send me your e-mail, I’ll be glad to send it to you 😉
    Justin Productions
  • Aroonzfx
    December 11, 2005 at 7:09 pm
    hi justin
    can u send me the psd file to
    arun_p_g@rediffmail.com
    thanx in advance
    aroonzzzz
