Activity Forums Maxon Cinema 4D Creating objects out of cigarette smoke
  • Creating objects out of cigarette smoke
    Posted by David Wiffen on January 5, 2011 at 4:16 pm
    Hi All,
    Just wondered if anyone had any good ideas or plugins to create objects out of smoke, quite whispy like cigarette smoke.
    So say I have quite a complex shape, like a persons head, I want the smoke to emit and form the head shape and then react to movement.
    I have looked at DPIT and Turbulence 4D – but not too impressed. It needs to be quite high end.
    Any ideas would be welcomed 🙂
    Adam Trachtenberg replied 15 years, 7 months ago 3 Members · 2 Replies
  • Jason Stirret
    January 5, 2011 at 11:49 pm
    How about using two separate renders. One with smoke as you want it, and another using an alpha with whatever smoke material you are using projected onto a spine (creating the shape you choose). You could then composite the two in Photoshop.
  • Adam Trachtenberg
    January 6, 2011 at 3:41 am
    Here’s one with DPIT Effex: https://www.3danvil.com/tutorials/Head%20Smoke%2002.mov
    Could certainly be improved with more work.
