Activity Forums Adobe After Effects Creating motion title in After Effects
  • Creating motion title in After Effects
    Posted by Olaf Steel on January 11, 2009 at 3:58 pm
    I am editing a commercial in Final Cut Pro for a college project and want to create a title in After Effects for the catch-fraze at the end.
    Basically I would like to export a freeze-frame from Final Cut and import it into after effects.
    the effet I want is to have the title ‘Let Kodak Capture your Imagination’ to appear as if its being written accross the still image. I dont need to see a pen or anything writing the lettering, it just needs to appear as if being written. The writing has to appear quite qucily as well, as I dont want it to take too much time off the commerical as it has to be 30 seconds in total.
    I’m sure this is easy enough to do, but I have little understanding of after effects and am trying to use this opportunity to learn a bit.
    If you have any help with this, I would be very greatful. remember I dont know much about After Effects, or what is the best export setting to use in Final Cut.
    The version of After Effects I’m using is CS3.
    Thank you,
    Olaf
    Olaf Steel replied 17 years, 8 months ago 3 Members · 3 Replies
