Activity Forums Adobe After Effects Creating motion menus for Encore
  • Creating motion menus for Encore
    Posted by Todd Schmidt on June 8, 2007 at 6:42 pm
    Hey all,
    Well, I’m trying to nail this one down but all the tuts I look at seem to dance around the issue. I know the make buttons option and all that but what I really want to know is how you set up the animation to play then have the buttons appear and the animation stop. Can this all be done in one comp and brought in to Encore through Dynamic Link? I can’t seem to get it to work correctly. Any help?
    Todd
    Graham Quince replied 19 years, 3 months ago 3 Members · 3 Replies
  • Erik Pontius
    June 8, 2007 at 7:27 pm
    There are many ways to do this. You can create your motion menu in AE and have your buttons come up and then ride that out for a set time…say a minute or two. Then in Encore, set the Loop point to the time at which the buttons in the animation have come up completely. The loop point is the point at which the button overlays will appear. At the end of the two minutes it will loop back to that point again.
    The other common method is to create your animation, have your buttons come up…Export a still frame from AE of the menu with the buttons all the way up. Import the animation in as a timeline and import the still frame PSD as a menu. Set the animation as a first play and have the end action for the timeline be the still menu. When the disc is inserted, the animation will run, the buttons will come up and then it will drop you to a still of the menu with your buttons and overlays.
    There are other methods I’m sure…these are just a couple of ways to do it.
    Erik
  • Todd Schmidt
    June 8, 2007 at 8:09 pm
    Thanks….I’m gonna try these!
  • Graham Quince
    June 9, 2007 at 8:01 am
    My personal preference for this sort of thing is to use ‘invisible’ buttons prepared in photoshop. I’ll create a DVD menu in after effects with the buttons appearing, then prepare the buttons from a still in Photoshop, using a rectangle to makr out the button. Before I save this file though, I turn off the rectangle layer, as I would for any highlight layer too.
    Once in Encore, the software picks up the shape of the rectangle and turns the whole thing into a button
    Graham
    https://www.quinceweb.com – web design
    https://www.shiveringcactus.bravehost.com – Free FX for amateur films
