Activity Forums Apple Final Cut Pro Legacy creating mattes/masks
  • creating mattes/masks
    Posted by Jennifer Higgs on September 12, 2009 at 10:47 am
    I’m not sure what the difference between a mask and a matte is but what I want to achieve is the following. I want to create my own shape which I will use as a window through a video scene to see another scene beyond. I did this to a certain extent with making a black shape created in photoshop with a transparent background but I couldn’t work out how to get the black of the shape to get replaced by the 2nd video track. As well as this I would like to achieve 2 colored & feathered edgings/rims around the ‘window’. Thanks for any help you can give.
    Cheers, Jenny
    Jennifer Higgs replied 16 years, 11 months ago 3 Members · 3 Replies
  • Rafael Amador
    September 12, 2009 at 2:54 pm
    If you use a Photoshop document with transparency, the transparent areas will be “filled” , no the solid one. To use it as a mask in FC you need to use the “Alpha Travel Matte” function.
    You can just make a black and whithe document in Photoshop. The white areas will be solid in Fc, whilethe gray level will determine the transparency in FC, being the black 100% transparent.
    In this case you need to set the foreground layer as “Travel Matte Luma”.
    More in the Biscardi’s tutorial about mattes and masks here in the forum.
    Cheers,
    rafael.
    http://www.nagavideo.com
  • David Roth weiss
    September 12, 2009 at 3:18 pm
    Here is the tutorial Rafael mentioned.
    https://library.creativecow.net/articles/biscardi_walter/FCPTravelMat1.php
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Jennifer Higgs
    September 16, 2009 at 3:30 am
    Thanks guys. This has been helpful. Its a whole new world of learning. Can’t quite understand why you offer this service for free but so glad you do. Look forward to more. Thanks again. Jenny.
