Activity › Forums › Adobe After Effects › ‘Creating Mask on a Shape Layer’
  • ‘Creating Mask on a Shape Layer’
    Posted by Jason Ke on October 6, 2016 at 9:42 am
    Hi everyone,
    I came across a problem when I have a picture that I want to hide behind inside part of my background footage.
    It works well for me when i try to use a solid layer and create a mask on it, then apply alpha track matte to my picture.
    but when i try the same method for shape layer (i.e i create a mask on my shape layer and the apply track matte), it doesn’t work out well.
    I tried the other way to tackle the problem:
    Apply a set matte effect to my masked shape layer. It can’t work as well.
    Your help will be highly appreciated.
    Thank you.
    Jiaze
    Roei Tzoref replied 9 years, 12 months ago 2 Members · 7 Replies
  • 7 Replies
  • Roei Tzoref
    October 6, 2016 at 10:00 am
    I am not sure why in this case you need a mask on top of a shape, instead of using just the shape but if you want to add a mask on a shape look in the tools panel as your shape is selected and you will see a small icon that when it’s turned on, the path tools will draw a mask instead of a shape.
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
  • Jason Ke
    October 6, 2016 at 8:52 pm
    Thanks for your reply.
    I know I am done. But curiosity brought me here.
    Why it can’t work for the masked shape layer?
    The attached picture is the case I achieved using solid layer.
    Thank you
    Jiaze
  • Jason Ke
    October 6, 2016 at 8:53 pm
  • Jason Ke
    October 6, 2016 at 8:56 pm
    Thank your for your reply.
    I know how to draw a mask on shape layer.
    The question is if I want to show a picture underneath the masked shape layer (turned the visibility off and then apply alpha track matte to it), It can’t work like the case when using a mask solid layer.
    Thanks again.
    Jiaze
  • Roei Tzoref
    October 6, 2016 at 9:12 pm
    This should work. Please drag and drop here a screenshot of what happens when you use a shape with a mask as a track matte.
    Roei Tzoref
  • Jason Ke
    October 6, 2016 at 9:56 pm
    I have figured it out (I need to use a solid shape layer).
    Another question is:
    How to apply set matte effect?
    (When I set the second layer as a track matte, it works well)
    (When I apply a set matte effect to the second layer, it cant work. I wanna achieve a track matte effect like below)
    Thanks again for your help!
    Jiaze
  • Roei Tzoref
    October 7, 2016 at 8:45 am
    A solid layer is one thing, a shape layer is another. A mask on a solid can be a track matte. A shape layer can also. A mask on a shape too. If theres is an issue with your masked shape not helping you get a decent alpha channel then you can drag and drop your aep file here and we can look at it.
    Set matte is another way of using a matte for masking. It should usually be instead of track matte and not in addition.
    You should read here to get a better understanding of how masking and mattes are manipulated in Ae to create alpha channels: https://helpx.adobe.com/after-effects/using/alpha-channels-masks-mattes.html
    Here is explaination on the set matte effect: https://helpx.adobe.com/after-effects/using/alpha-channels-masks-mattes.html
    Roei Tzoref
