Activity Forums VEGAS Pro Creating Lower Thirds in Photoshop to import into SVP 11
  • Creating Lower Thirds in Photoshop to import into SVP 11
    Posted by Ron Whitaker on April 22, 2012 at 2:00 am
    I created an animated lower thirds in Photoshop CS5, using PS’s animation feature.
    When creating the lower thirds, I have the background set to transparent, then I added my elements that I want to move into place.
    I set the bitrate of the file to 32, then render the lower thirds animation in Photoshop to an MPEG-4 format.
    When I bring the clip into SVP 11, the background in black. How can I render a lower-thirds animation in PS, then bring it into SVP with a transparent background?
    Do I need to do something in PS, or in SVP?
    Thanks for any responses.
    Stephen Mann replied 14 years, 4 months ago 3 Members · 3 Replies
  • Stephen Mann
    April 22, 2012 at 2:20 am
    I am pretty sure that MP4 does not support an alpha channel. Export it from Photoshop into a series of PNG files then import that into Vegas as an image sequence.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Tyson Onaga
    April 22, 2012 at 3:41 am
    To have an alpha, you will need: avi (uncompressed), mov (animation), or mov (png). Or a series of png images (as Stephen mentioned).
    However, another technique (from a DJ tutorial by D. Eric Franks) to get transparency:
    a. Add track, insert clip
    b. Add FX Sony Mask Generator
    c. Add track below, insert clip
    d. Make track (c) a child of track (a)
    e. Duplicate track (a) [another track with the Sony Mask Generator]
    f. Drag track (e) below track (c)
    g. Change track (a) compositing mode to Multiply
    I.e.:
    Track 1 – clip, Mask Generator, Multiply
    Track 2 – clip, Source Alpha, child of Track 1
    Track 3 – clip, Mask Generator, Source Alpha
  • Stephen Mann
    April 22, 2012 at 1:36 pm
    I thought of another.
    I use Videotagger for my credit rolls and it makes a white text on a black background. No alpha. When I want the end of the video to show under the credit roll, I just use the Vegas chromakey to key out the black.
    Steve Mann
    http://www.mmdv.com
