Activity › Forums › Adobe After Effects › Creating lights in AE – (NO 3D)
  • Creating lights in AE – (NO 3D)
    Posted by Michele Poggi on October 12, 2012 at 1:32 pm
    I’m thinking about how to create rays of light and light itself manually in After Effects, without using its 3D lights or plugins like Red Giant or Sapphire..
    I have to re-create the lights inside a box that has a ray of light coming from a hole.. Inside of the box there is a littler box and a Lego toy.
    I’m using masks and adjustment layers to play with curves and levels, and about the ray of light I’m thinking about extreme fractal noise well composed trough the hole, maybe with polar coordinates.
    Do you know any other way? Thanks as always for the constructive discussion guys.
    “Freelance Post-Producer”
    Editor Video
    Graphic Designer
    Digital Compositor
    Mail: snm.poggi@gmail.com
    Mobile: +39 3349129191
    Skype: sabakunomaiku
    John Cuevas replied 13 years, 11 months ago 2 Members · 2 Replies
  • John Cuevas
    October 12, 2012 at 2:13 pm
    Here are a few tutorials: This one includes a script at the end. All you have to do it is have a comp with a layer and a camera, run the script and it will create volumetric light look. I find that the fractal noise layer is to defined if you run that script. So after you run the script, press “T” to reveal the opacity and you should see this expression: (thisComp.layer(“Light 1”).active) ? 100 : 0; If you change the 100 to say 50, as you will cap the max opacity of the layer to 50. And the is controlled by increasing and decreasing the intensity of the light.
    Also adding a simple expression the evolution of the fractal will make it seem that the “dust” in the light is moving. So alt-click the evolution stopwatch and something like(remove the quotes)— “time * 90” will give you nice slow moving particles.
    https://www.petertorpey.com/tutorials/volume_light/
    https://maltaannon.com/after-effects/volumetric-lights/
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Cuevas
    October 12, 2012 at 2:35 pm
    Found a COW Tutorial too: https://library.creativecow.net/articles/drozda_jerzy/VolumeLight/video-tutorial
    Thinkck.com
