Activity › Forums › Adobe After Effects › Creating gradiant halftone Alpha Layer in PShop for AE
  • Creating gradiant halftone Alpha Layer in PShop for AE
    Posted by Joshua Ferg on November 8, 2005 at 3:14 pm
    Hi –
    Posted this in Pshop but responses are slower there.
    I’m trying to create a gradiant halftone effect for import into AE – I want to use the white element of the gradient as an Alpha to expose another layer beneath.
    Very frustrated — any suggestions greatly appreciated!
    Thanks for your time.
    Josh
    Joshua Ferg replied 20 years, 10 months ago 3 Members · 4 Replies
  • Chris Smith
    November 8, 2005 at 3:48 pm
    Use can use the ramp effect on a layer in AE. Set it to do the gradient you like. Then use this as an alpha track matte above the layer you want to effect. You may have to pre-comp the ramp layer.
    Chris Smith
    https://www.sugarfilmproduction.com
  • Joshua Ferg
    November 8, 2005 at 3:57 pm
    Hey Chris –
    Thanks for the feedback.
    Here’s the issue – I need to get the halftone effect on the layer so what I end up with is essentially a graduating ramp of the dots in size as well as color. I can then drop that layer onto layer B – also a gadient.
    I thought maybe creating 2 layers in PShop one gradient color and the other the halftone dots was best.
    Is it an overly-complicated solution? Any ideas?
  • Michael Szalapski
    November 8, 2005 at 4:20 pm
    In photoshop create a gradient layer. Duplicate it.
    Run the halftone effect on one layer, try different settings ’till you get a good ‘un. Then use colour select (or similar) to remove one of the colours, white or black. (I’m assuming this is b&w?) You should have dots on a layer by themselves.
    Then you could group the gradient layer onto it and you’ll have dots with a gradient!
    Or you could do this whole thing in AE, which will make you much cooler. http://www.petewarden.com provides you with some lovely (FREE!!!) AE plugins, one of which is halftone. Do something similar to the instructions I just gave you for photoshop in AE and you will have great success.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great)
  • Joshua Ferg
    November 9, 2005 at 1:08 pm
    Michael –
    Sorry for the delayed response – but thanks. It worked like a charm.
    Also – downloaded the Plug In’s and will take some time to explore them.
    THanks again for your time.
    Josh
