Activity Forums Adobe After Effects Creating glowing spot along edge
  • Creating glowing spot along edge
    Posted by Peter Jansen on May 17, 2009 at 9:53 pm
    I’m trying different stuff I found on this forum to create my effect, but can’t make the right one.
    This is what I want: a small moving glowing spot along a edge. You find this a lot on scorebords in sport programs. See the picture below for an example. The moving spot is above the period/time part or a small one without dot is above the ‘1’ of NY (ignore the glowing part at the left of the period/time).
    (yes, I’m a hockey fan 😉 )
    I think it’s not that difficult, but I think I need the right start. Found lots of effects with lines, glows, etc, but can’t find a way to match the moving spot (with the trail on the left and right). Hope someone can help me.
    Thanx in advance.
    Greetz,
    Jeroen
    Peter Jansen replied 17 years, 4 months ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    May 18, 2009 at 7:02 am
    You’re looking at Effect>Generate>Vegas.
    You’ll need to draw a mask with at least three vertices to get it to work. Also set VEgas towork with a mask instead of the default, Image Contour.
    You’ll have to swap the values for starting and end values to get the streak to look right – ie. thick to thin. You animate Vegas using its rotation parameter.
    Add some Glow to taste and use the Add Blending Mode.
    Would you be interested in two, near mint Lemieux rookie cards?
    Cheers
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available).
    Adobe After Effects Training in South East Asia.
  • Peter Jansen
    May 18, 2009 at 6:42 pm
    Thanx, this was exactly what I was looking for. Perfect! Little bit of fine tuning, and a nice result now. 🙂
