Activity › Forums › Boris FX Particle Illusion › Creating Flying Dirt With PI 3.03?
  • Creating Flying Dirt With PI 3.03?
    Posted by Don Caughman on May 20, 2008 at 2:13 am
    I have been looking through all my libraries trying to find a emitter that will allow me to create the effect of dirt particles flying off of the ground like
    when someone stomps the foot in the dirt or when a auto tire or tank tread rolls across and sandy or loose dir surface. Is it possible to do with the prsent libraries that come with PI 3.03 and Monthly entries??
    Thank You
    Don Caughman replied 18 years, 4 months ago 2 Members · 2 Replies
  • Alan Lorence
    May 22, 2008 at 12:57 pm
    There are “dust puff” emitters in one of the libraries (at least one), if that’s what you’re looking for. Make sure you have all of the libraries, then use particleView to search for “dust”.
    Alan.
    http://www.wondertouch.com
  • Don Caughman
    May 24, 2008 at 4:01 am
    Alan Thank You for your suggestion, however,
    the dust puff cloud is a little to wispy and light looking
    to look like dirt. Maybe it can be modfied.. Is it possible to modify the parameters to make th particals appear larger and more dense while possessing the proper physical motion??
    If it is possible maybe someone could give me some pointers
    on the necessary changes to be made. Perhap PI is not suited for this type of applications. That is why I am asking whether I am looking at the wrong application for the described task. If ther are any suggestions on how to acomplish this task your input would be most appreciated.
