Activity › Forums › Apple Final Cut Pro Legacy › creating DVD help
  • creating DVD help
    Posted by Zeliha Bozkurt on June 1, 2006 at 3:28 pm
    Hi I am trying to create a DVD of my sequence but failing miserably. 🙁
    I compressed my sequence using Compression dvd 90 mins fastestst encode. Which gave me an mpeg2, aiff and a dolby ac3 files
    I then tried to add the audio and video into DVD Studio projects palett tab but in the add video/audio tab all the above files were greyed out .
    Is there a simpler way to create DVD
    Can anyone help.
    Zee.
    Don Greening replied 20 years, 4 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    June 1, 2006 at 4:39 pm
    It should be as easy as importing the two files as an asset, then draging them together to a button and select “make track, connect to track”…
    Jerry
  • Don Greening
    June 1, 2006 at 4:59 pm
    As Jerry has pointed out, instead of trying to access your media from the palette tabs, go to the file menu and choose: Import>Asset. Navigate to the folder where your media files are and import them. The imported media will now appear in the assets tab in the lower left side of the DVDSP screen.
    – Don
    “Please take a moment to fill out your profile, including your computer system and relevant software. Help us help you.”
