Activity Forums VEGAS Pro Creating DVD from Elementary Streams
  • Creating DVD from Elementary Streams
    Posted by Rick Hughes on February 3, 2014 at 7:06 pm
    Using DVD Architect 5 to create PAL stereo audio DVD
    On advice I have opted to created project using Elementary streams
    Used Movie Studio … and MainConcept DVD PAL Stream Render template … selected
    include‘ audio and on system selected ‘separate elementary streams
    This creates post render:
    video_file .m2v
    audio_file.mpa
    When I go into DVD Architect … and create ‘new’ … ‘single movie – PAL DVD – AC3’ it then presents me with a browse window …. which file do I choose or doesn’t it matter if they are in same folder ?
    If I select the audio_file.mpa it also loads a video track, if I select the video.m2v video it also loads an audio track. Is this normal ?
    Not sure of sequence to follow.
    Rick Hughes replied 12 years, 7 months ago 2 Members · 4 Replies
  • Edward Troxel
    February 3, 2014 at 7:25 pm
    Your audio file has to be an AC3 file – not an MPA file. You rendered the audio to the wrong format.
    Edward Troxel
  • Rick Hughes
    February 3, 2014 at 7:40 pm
    If I select ‘elementary stream’ in system tab there is no choice it states it will create mpa & m2v files … no option to select audio codec.
    I could of course render twice and use AC3 template ………… seems strange that it allows invalid elementary streams ? … is there a reason for that ?
  • Edward Troxel
    February 3, 2014 at 8:36 pm
    Yes, you have to render twice. As has been said in the various threads you have started here, you render the video to MPEG2 and then – on a second render – the audio to AC3. It takes two separate renders.
    Edward Troxel
  • Rick Hughes
    February 3, 2014 at 9:15 pm
    Thanks .. I raised the separate Q’s to avoid complicating the issue, wasn’t trying to be difficult.
    Been 5 days on trying to get this sorted.
    I sort of expected Vegas & DVD architect to be easier when it came to creating the DVD ……… I was wrong.
