Activity Forums VEGAS Pro Creating dvd
  • Creating dvd
    Posted by Toneystone on April 11, 2007 at 7:23 pm
    I’m trying to import video only from a dvd and import a seperate audio file but I want the audio file encoded in to DTS because I have the Surcode DTS. How can I burn the both files and do I need to burn in Sony’s DVD architect or can I use my preferred software, Nero 7?
    Toneystone replied 19 years, 5 months ago 2 Members · 8 Replies
  • 8 Replies
  • Laszlo Kovacs
    April 15, 2007 at 7:47 am
    I always burn with nero, DVDA just prepare.
    Sorry, I have no idea about DTS.
    By(t)e
    K.L.
  • Toneystone
    April 16, 2007 at 1:11 pm
    Thanx Laszlo for replying. Is your audio file in 5.1? If so,in Nero are you using their AC-3 template or is your audio file already in 5.1 when you import it into Nero vision?
  • Laszlo Kovacs
    April 16, 2007 at 3:22 pm
    I never used nero vision.
    My audio is always stereo, but yes, it’s ac3.
    I just BURN all my disks with nero regardless of it’s
    type – be it DVD video, DVD, svcd, or cd.
    I’m happy with nero, becasue it allows me to do some
    special things, example: a video DVD containing
    additional data (not sure about supporting this method
    by others…)
    I used nero for years now, and almost without problems.
    DVDA just prepares the DVD, that means it creates the
    necessery files into a video_ts folder (vob, bup, ifo files).
    Nero does not too much care for the contents of these files
    (at least it seems to do so).
    So, if you’re about multichannel audio, render it with vegas,
    author and prepare the disc with dvda, and burn it with your preferred burner (may be nero, but could be DVDA itself).
    Hope I could help.
    By(t)e
    K.L.
  • Toneystone
    April 16, 2007 at 3:52 pm
    I dont have DVD Architect yet with my Vegas. Do you know if I can import an audio wav file (DTS) and a video file (VOB,MPEG,etc..) and burn it Nero?
  • Laszlo Kovacs
    April 17, 2007 at 3:33 pm
    [toneystone] “I dont have DVD Architect yet with my Vegas”
    Oooops…
    I thought you have…
    Sorry, I have no idea about nero vision express, I never used it.
    But I bet, it must not refuse to import already DVD compliant stuff
    (such as mpeg2, ac3/mpeg audio).
    Again, I’m not sure about DTS.
    Sorry if I could not help.
    By(t)e
    K.L.
  • Toneystone
    April 19, 2007 at 2:42 pm
    I’m trying to import video that already has an audio file but I want import another audio file in DVD arhitect. It appears that the video will not in sync with my seperate audio file. It previews as two files not joined together. Can I combine the video file that has audio with another audio to play in sync? Or do I have to delete the audio from the video first in order to attach the seperate audio file?
  • Laszlo Kovacs
    April 19, 2007 at 3:59 pm
    [toneystone] “Can I combine the video file that has audio with another audio to play in sync?”
    Sure.
    But you have to ensure a/v sync in vegas.
    (In DVDA I don’t know of a way to alter the position
    of the audio.)
    By(t)e
    K.L.
  • Toneystone
    April 19, 2007 at 5:38 pm
    Is it possible to import Mpeg file with resolution of 1920 X 1440 into Vegas and Architect 4? I have a program that converts files into that resolution.
