Activity › Forums › Maxon Cinema 4D › creating bingo balls
  • Randy Johnson
    November 12, 2010 at 6:40 pm
    Its all texture work. You need to try a couple different projection settings for the texture…. if you cannot get that to work open up body paint and layout the UV’s there you can send the outline to photoshop or paints it right there.
    not sure I would both with an hdr for that either.
    Check c4dcafe.com for tutorials.
    /Randy
  • Victor Camacho guerrero
    November 15, 2010 at 3:53 pm
    Hi Randy,
    thanks a lot for your reply. Due to my limited experience in Cinema 4d, I still cannot find any proper way to apply that texture in the different projection. I have done some research in internet, but nothing properly I have found.
    Any link where I can find something like that??
    Many thanks.
  • Randy Johnson
    November 16, 2010 at 8:13 am
    https://www.c4dcafe.com/ipb/index.php?/files/category/3-texturing-bodypaint/
    You need to sign up as a member then you can see the tutorials… there are a few for textures. I have not watched them but Kiwi’s tutorials are very good in general.
    /randy
    November 16, 2010 at 9:43 am
    thanks a lot for your answer, i will investigate!
    November 17, 2010 at 12:43 pm
    finally i got it. The best solution and faster I found it was downloading some pool balls model, and I use and modify the jpeg. I used for the texture for my ball and now looks great!
    Many thanks
