creating audio-only master clips to export for mix
Hello folks, this is my first desperate plea for help here. I’m doing a festival-application finish of a doc feature and will be doing sound post in Soundtrack Pro. I want to break the film up into reels, consolidate the media and export only the audio with three-second handles and a rendered low-res QT video to mix to. The film was shot on DVCPRO HD 720p24fps. I’ve experimented with unlinking, making clips independent, creating new master clips, copying and recompressing in the Media Manager, but I always end up with media files that contain video. For mixing purposes this is unnecessary, eats up space and I get messages in STP that my disk is too slow (even running off an esata drive). If I make a custom export setting to minimize the data-rate of the video, it takes forever to recompress. In my good-old-Avid days, I used to duplicate a sequence, delete all the video, and then “Consolidate”. Any ideas on how to achieve the same effect?
Many thanks in advance,
Eben
