Activity Forums VEGAS Pro Creating and playing .mov files with Vegas and DVD Arch
  • Creating and playing .mov files with Vegas and DVD Arch
    Posted by Don Kimball on August 29, 2009 at 5:49 am
    Okay — well the good news is that I successfully created a file that friends and associates could play in their Mac Computers by rendering the file in DVD Architecht as a .mov file.
    Now for the issue at hand: The file opens in Quicktime without a problem, however when it is played it stalls and freezes and then continues only to freeze again, then continue until the end is eventually reached. I tried this on another computer in case it was a memory problem and the same issue was present.
    I looked for settings in the rendering section so that I might tweak or change a setting but didnt know what to adjust.
    Any tips on this one please?
    Adam Rose esq. replied 17 years ago 2 Members · 1 Reply
  • Adam Rose esq.
    August 29, 2009 at 6:11 am
    what rate did you render it at, in terms of mbs?
    max should be 8mbs
    also, to create a .mov, you shouldn’t be using DVDA at all, since not creating a DVD, and Vegas has far more control over rendering customisation than DVDA.
