Activity Forums Adobe Premiere Pro Creating and on screen score count
  • Creating and on screen score count
    Posted by Nick Blake on May 16, 2013 at 1:45 pm
    Hi there,
    Pretty basic question here, but hoping there’s an easy work-around to what could otherwise be a fairly labour intensive job…
    I have video footage of a two guys playing a game of ping pong and I need to have an on screen visual, which denotes the score as the game progresses. Is there a simple way of doing this in titles, or is it a case of creating a new title card for each new score and placing them in a sequence over the footage?
    Your advice is much appreciated.
    Cheers,
    Nick
    Kris Merkel replied 13 years, 3 months ago 3 Members · 2 Replies
  • Steve Brame
    May 16, 2013 at 2:34 pm
    If the design allows, just create a single title with the background look of the scoreboard, place on one track, then create titles for the numbers that you’ll need, then just drag them to the track above as you need them. Couldn’t be much simpler than that.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID5 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * CS6.x Creative Cloud
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Kris Merkel
    May 16, 2013 at 2:40 pm
    Create 15 unique titles with the # and as you go through your sequence place a title where you need it. Then as you go through your timeline when you need to change the title to a higher #. Select the title you need in the bin and then right click on the clip in the sequence and choose “replace clip from Bin”
    Cumbersome at first but will go smoother as you go through your edit.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
