Activity Forums Adobe After Effects Creating and animating displacement in a video/photo?
  • Creating and animating displacement in a video/photo?
    Posted by Brandon Liu on August 18, 2017 at 3:40 am
    I saw this effect is numerous videohive projects, and I was curious about how it is done.
    Here are some image examples:
    Thanks in advance!
    Steve Bentley replied 9 years ago 3 Members · 2 Replies
  • Greg Gesch
    August 19, 2017 at 3:32 am
    Hi, you could look at the Displacement Map Effect which uses a separate black/white/greyscale image to offset sections of the original image.
  • Steve Bentley
    August 19, 2017 at 8:47 am
    Use Greg’s suggestion of Displacement effect but use a noise on another layer as the source for the diplace. If you use a large scale version of the cell noise or a few others you will get exactly this look and it can animate – no masks required.
