Activity Forums Adobe After Effects Creating an apple movie trailer aspect ratio from 4:3 format
  • Creating an apple movie trailer aspect ratio from 4:3 format
    Posted by Paul Meyer on January 30, 2007 at 2:50 pm
    Hello,
    I’m attempting to make a trailer similar to the look of apple’s movie trailer size.
    Their trailers aren’t exactly 16:9. How can I achieve this format from existing 4:3 footage?
    Any advice would truly be appreciated.
    -Paul
    Paul Meyer replied 19 years, 7 months ago 2 Members · 2 Replies
  • Mark
    January 30, 2007 at 3:40 pm
    Create your original comp in a reduced sized 16:9 format (360×240 widescreen) then simply place footage in the screen and adjust position.
    Mark
  • Paul Meyer
    January 30, 2007 at 4:48 pm
    I’m still a bit confused after several attempts…
    When you’re in the Composition Settings window:
    What Preset should be used?
    I unlocked Aspect Ratio to 4:3.
    I used NTSC DV and then set the width to 360, height 240.
    Then the Frame Aspect Ratio changed to 6:5.
    I made a movie format of a Quicktime / Compression type H.264.
    The quicktime was close to size, but not the exact look of the apple movie trailers.
    Any more advice would truly be appreciated.
    -Paul
