Activity Forums Adobe Illustrator Creating an animation in Illustrator
  • Creating an animation in Illustrator
    Posted by Maria Reverbei on April 27, 2013 at 5:19 am
    I animate mostly using Flash. It’s been a while since I’ve created an animated sequence in illustrator and would like to try it again. Does anyone know how to do this? Thanks everyone 🙂
    Maria Reverbei replied 12 years, 10 months ago 2 Members · 2 Replies
  • Vincent Rosati
    August 7, 2013 at 11:59 pm
    I don’t think I’ve ever animated with Illustrator, per se.
    I might create multiple artboards if I needed to do cells.
    Otherwise, I might have one master file with all of the elements.
    …just some general thoughts.
    Did you make any progress with this?
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
  • Maria Reverbei
    August 13, 2013 at 1:26 am
    Thanks Vince.
    I actually put it aside due to work load. I do remember creating the animation by using different layers for each movement, then using automation (years ago!). When I get some time, I’m gonna give it try.
    Maria
