Activity Forums Adobe After Effects Expressions Creating a working Aircraft HUD in After Effects or Nuke
  • Creating a working Aircraft HUD in After Effects or Nuke
    Posted by Wilmar Luna on November 20, 2013 at 8:44 pm
    Hey guys,
    I have a super complex project that I could use some tips for. I’m a very visual learner, so here is a perfect example of what I want to build:
    https://www.loop-net.info/hud/fl.html
    The set up:
    – Using Cinema 4D, I want to create a camera that will be attached to my characters head in order to create a first person view. It will fly around the city at different altitudes and angles.
    – I then want to migrate the camera data into After Effects and add things like altitude, vector, positioning, etc. This is to create a futuristic HUD for an armored female superheroine from my book The Silver Ninja. https://www.thesilverninja.com
    The problem:
    1.) I was thinking of using a mask and an offset to have the lines scroll on the screen. But like in the link I provided, I don’t want the lines to go over the vector. So I thought I’d use a mask, but if I do a mask then I’d need to pre comp the altitude lines. And if I pre-comp, then I might not be able to link the expressions to the camera positioning and data.
    2.) How would I get the numbers to increase and decrease in value as the character changes altitude? I know a few basic expressions, but this seems a bit more complicated than that.
    Here’s my very basic and crude attempt for 2006 or so.
    https://www.youtube.com/watch?v=0tjJKDimCAY
    (You can see that the “3D” city in the upper right moves a little bit, but again, it’s not quite what I wanted.)
    Any starter tips would be a GREAT help for me.
    A superheroine book I wrote – https://www.thesilverninja.com
    Wilmar Luna replied 12 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
