Activity › Forums › VEGAS Pro › Creating a travel map in Sony Vegas
  • Creating a travel map in Sony Vegas
    Posted by Don Kimball on February 3, 2006 at 5:27 pm
    Well I have had some great experiences using Vegas but one thing eludes me. I was trying to create a map showing my travels in Africa. I got a great map from Encarta which works well and zooms in nicely.
    However even though I could create a text media file in Vegas naming the location as the map zooms in I wanted to also trace the route somehow. I could only find straight text available so I put in fading * (asterisks) to show my location and route traveled but it looks rather lame. I wanted arrows gradually tracing the route… Any idea how to import arrows and or some other cool graphics that show a route traveled?
    Thanks again!
    Don
    Don Kimball replied 20 years, 8 months ago 2 Members · 2 Replies
  • Edward Troxel
    February 3, 2006 at 9:37 pm
    Here’s an easy way:
    Have TWO maps, one without the line and one WITH the line. Now fade from the without to the with and change the transition to a linear wipe (works especially well if the line is going straight across.)
    Edward Troxel
    JETDV Scripts
  • Don Kimball
    February 6, 2006 at 6:39 pm
    Thanks very much Ed
    I also found another way which I found worked beautifully but took a bit more work.
    Since I had about 5 legs of the road to show that this is how much I traveled on the map I created five different maps from the same gif of the original map. I used microsoft paint to draw each of the lines. Each map showed a progression of one more line indicating traveling to the destination.
    I merged each of these 5 gifs on the video track on Sony Vegas so that they faded one into another in rapid succession. The result was a beautiful effect of the line gradually increasing on the route map quickly and clearly.
