Activity › Forums › Adobe After Effects › Creating a transition between two vectors
  • Creating a transition between two vectors
    Posted by Ezra Hames on September 15, 2016 at 5:13 pm
    I am wondering if anyone can help.
    I’m currently working on a project, where I need a giraffe to move its head from an upright position to the ground.
    I’ve created a vector of the giraffe with its head up and a giraffe with its head down.
    What is the best/ most realistic way to combine these two vectors, making a realistic motion?
    Thanks in advance.
    Roei Tzoref replied 10 years ago 4 Members · 4 Replies
  • Kalleheikki Kannisto
    September 15, 2016 at 7:00 pm
    Use a single image and use the puppet tool to move the head.
    Senior Graphic Designer
  • Daniel Waldron
    September 15, 2016 at 7:03 pm
    The most realistic way is to create the frames in between. Obviously that is significantly more work. It sounds like the Puppet Tool is what you are looking for.
  • Ezra Hames
    September 15, 2016 at 7:10 pm
    Thanks for the reply!
    I need the ‘upright’ position to look exactly like the vector and the ‘head down’ to look exactly like the vector. Is there a way to achieve this using the puppet tool?
  • Roei Tzoref
    September 15, 2016 at 11:41 pm
    puppet will work on one image. but there are manipulations you could use to make this transition seamless to another image. could you share a screenshot? we could know better what specific suggestions to give based on specific images.
