Activity Forums Maxon Cinema 4D Creating a surface from points
  • Creating a surface from points
    Posted by Will Macneil on June 23, 2005 at 4:02 pm
    Anyone know a trick or plugin for creating a surface from a group of points (as many as 10,000.)
    I’m happy to go into another app if that helps.
    Will
    Will Macneil replied 21 years, 3 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    June 23, 2005 at 4:15 pm
    I don’t know of any plugin for Cinema, but I have a Rhino plugin that will do this (Terrain). If it’s a one-off thing I might be able to make the surface for you–depending on what format it’s in.
  • Will Macneil
    June 23, 2005 at 4:23 pm
    That’s very kind Adam. At the moment, I’ve just got loads of points created from a spreadsheet of x and z coordinates. I’ll add the y coords later. I imported the coords via the ascii import in the structure menu. So I can output the point cloud from C4D as any format of model or I can just pass on the spreadsheet.
    Since this is a paid job, I’d be happy to pay you a fee for this.
    If you’d still like to help, you can reach me here:
    will.macneil@bbc.co.uk
    Many thanks,
    Will
